Login Error
Close
Installing a Wall Furnace
by DoItYourself Staff
If you want to supplement the heating within your home, you may consider installing a wall furnace. Gas wall furnaces are capable of operating using natural gas, and this is an efficient and clean burning fuel.
Installing Your Wall Furnace
First and foremost you need to choose a gas wall furnace that is going to meet your needs. You need to determine how much area you have that needs to be heated. Are you attempting to heat a very large room or a relatively small one? This is going to determine what size of wall furnace you choose.
You need to install the gas wall furnace in the way that is specified by the manual. You want to keep the necessary amount of space between the wall and the furnace, and you want to make sure that the wall furnace is installed using a metal plate in order to produce the best and the safest results. The metal plate, when firmly attached to the wall and the furnace will ensure that the installation is sturdy.
The wall furnace should be installed on an exterior wall's inside and the vent cap needs to be flush against the exterior wall in order for you to get the most out of your wall furnace. This way, no moisture will get into the wall furnace.
 forum activity
