Login Error
Close
Installing Acoustic Foam
by DoItYourself Staff
what you'll need
  • Acoustic foam
  • Tape measure
  • Wall paneling or cardboard sheets
  • Hand saw
  • Electric carving knife
  • Foam tack/tube tack
  • Tacks and Tack hammer
  • Safety goggles
  • Dust mask
Acoustic foam is not only for sound or record studios but is an ideal noise insulation component for a normal room as well. If you want to turn your living room or bedroom to a complete, state of the art home theater package then installing sound insulating foam will produce the best sound results. Sound waves bounce off on any hard surface-including walls-and acoustic foam absorbs these sound waves to produce a better sound. The sound proofing properties will also ensure that your neighbors will always have a restful sleep. Here are the easy steps on how to install acoustic foam for your walls.
Step 1 – Take Accurate Measurements of the Wall
Use a tape measure to make careful measurements on the overall dimensions of your wall. You may opt not to put acoustic foam on the ceiling but doing so will produce the best results, both in terms of sound quality and sound deadening capabilities. Measure the overall height and width of your room to determine the amount of acoustic foam that is needed for the job.
Step 2 – Cut the Cardboard or Wall Panels to Size
Use a hand saw to cut the cardboard or wall panels according to the dimensions of your room. Divide each side of the wall into multiple panels for ease of installation. A modest sized wall can be divided into 4 to 6 panels per side. Cut the cardboard or wall panel according to size. The acoustic foam will be attached to each cardboard panel for easy installation. This will also allow you to remove the acoustic foam without damaging the walls in your room.
Step 3 – Cut the Acoustic Foam
Unroll or unwrap the acoustic foam and use an electric carving knife to cut the foam in accordance to the size of each cardboard panel. Wear safety goggles and a dust mask as you cut the foam.
Step 4 – Attach the Foam to the Panel
Apply a liberal amount of foam tack or tube tack to the entire back of the foam and attach to the cardboard panel. Foam tack is specifically formulated to be used on foam products and other sound deadening applications. Remember to put a moderate amount of foam tack or tube tack on the entire back side of the foam to prevent sagging when dry. With that being said, let the glue dry for at least 2 hours before proceeding.
Step 5 – Nail the Panels to the Wall
Grab the tack hammer and nail each panel to the wall. Remember to only nail on the edges of each panel to facilitate easy removal in the future. Start at the bottom or top corner of each wall and work your way from there. You may need to adjust the size of the panel to fit a particular corner of the room. You can use the electric carving knife to cut the panels accordingly.
You may then test the sound insulating properties of your room. Acoustic foam can be bought at the nearest hardware or home improvement center.
 forum activity
