Installing Air to Air Heat Exchangers: Mistakes to Avoid
Many homes in residential neighborhoods use air to air heat exchangers as a way to heat their homes. Air to air heat exchangers will do this job quite effectively and efficiently. Air to air heat exchangers will move air from one location to another, heating it as it goes. Installing an air to air heat exchanger is not an easy job and plenty of mistakes can be made. The article that follows shares some of those with you.
Size of the Unit
You need to know the size of your home when you purchase air to air heat exchangers. They are rated by cubic square feet. If you purchase a small unit, you run the risk of having cold spots or overloading it. Larger air to air heat exchangers may be overkill for your home.
Professionals
Air to air heat exchangers can be difficult to install. Look over the instructions methodically as well as study the current unit. If you feel over your head at any time, enlist the use of a professional. Doing so will decrease potential issues.
Help
If you are going to install air to air heat exchangers on your own, have a friend help. These units can be very heavy.
