Login Error
Close
Installing Brass Compression Fittings
by DoItYourself Staff
Homes with barrel clay tile roofs provide a home with great curb appeal. These rounded, clay tiles have been used throughout the centuries on homes throughout the world. Clay tile roofs are very durable and will last a long time, however, the installation process can be labor intensive and demanding. Clay tiles can be installed in a few different ways. You can nail them to wood battens, nailed directly into the roof itself, or with a mortar application.
Roofing Felt
To begin installing the clay tile roofs, you must lay down a protective barrier of 43lb. roofing felt. Lay this out in one continuous strip, overlapping each new row by 7 inches.
Install Flashing
Before laying anything down onto the roof, make sure you have your flashing installed. This will go around any edges and valley.
Lay out Chalk Lines
Make perfect measurements to ensure proper, and straight installation. Lay chalk lines both horizontally and vertically to ensure you stay with your design.
Install Tile
Place a copper nail in the specified area that the instructions call for. Follow your design, keeping measurements accurate, until you have finished the roof.
 forum activity
