Login Error
Close
Installing Ceramic Tile
by DoItYourself Staff
Installing ceramic tile greatly transforms a room. If you plan on doing a home installation yourself, there are numerous installation guides available to help with your project. This article lays out the basics, but installing ceramic tile may involve extra steps depending on the kind of tile, size, and foundation underneath your installation area.
Tools and Materials Required for Installing Ceramic Tile
• Ceramic tiles
• Grout
• Backing or foundation
• Adhesive or thinset
• Rubber mallet or hammer and block of wood
• Long piece of wood
Before You Install
Installing ceramic tile differs depending on whether you plan to install directly onto a wood surface, over vinyl or linoleum floor covering, or directly to a concrete slab. Tile experts discourage installing ceramic tile directly to a wood surface. You’ll need to install a sub-floor first. The same sub-floor is required for ceramic tile over vinyl or linoleum floor coverings. If installing ceramic tile directly to concrete, make sure you thoroughly clean surfaces before installation begins. Fill in any dips, cracks, waves or bumps in the concrete.
Installing Ceramic Tile Step-by-Step
Step 1 – Lay Out Room
Lay out the tile pattern on the floor before applying adhesive. Use a chalk line to snap a line perpendicular to the room’s length. Do larger tiles first, and then border tiles. Place tile spacers between the tiles. Next, place a long one-inch thick piece of wood perpendicular to the tiles, securing it with a screw gun. Lay tiles going across the room next to the board in both directions. Be sure to use spacers between the tiles. Once you’ve laid out the tiles, check spacing and shift tiles to achieve balance in the room. The line where tiles intersect the wood board is the point where you’ll snap a second chalk line. This is your starting point for installing the tiles.
Step 2 – Lay Tiles
With a notched trowel, apply a 2’ square of tile adhesive in your starting corner, using spacers between tiles and a level to ensure they’re flush. Use a rubber mallet (or hammer and block of wood) to nudge tiles down that are too high. Work across and down the entire room. Allow adhesive to set overnight.
Step 3 – Apply Grout
Make cuts and work on installing ceramic tile borders. Cut border tiles with a glasscutter or tile cutter. For more complex cuts, use a tile ripper or tile saw. Mix grout per manufacturer’s instructions and apply at a 45-degree angle. Wipe off excess grout with a sponge. Once your grout sets up, go back over to clean off any remaining grout. Allow grout to “cure” a full week before applying clear sealer.
Step 4 – Finishing up installation
The final step is to replace base moldings and furniture. Installing ceramic tiles is just that easy.
 forum activity
