Login Error
Close
Installing Fiberglass Blow In Attic Insulation
by DoItYourself Staff
what you'll need
  • Cellulose insulation
  • Cellulose blower
  • Tape measure
  • Metal flashing
  • Rulers
  • Cardboard
  • Long sleeves
  • Long pants
  • Safety Eyeglass
  • Mask
  • Hat or Cap
  • Gloves
Fiberglass blow in attic insulation is less costly that other types of insulation, but it is very efficient. However, this type of insulation can be a bit tricky to install, and if you do not use the proper methods of application, the results could turn out to be uneven and fluffy, which will not insulate well. Improper application can also cause health hazards, including irritations to the skin, eyes and lungs. For this reason, it is important to remove children and pets from the home while you work. Follow the instructions below for successful installation.
Step 1 – Determine the Area that Needs Insulation
Before anything else, you need to determine the square footage of your attic ceiling that needs insulation. You can easily do this by multiplying the length of the attic ceiling by its width.
Step 2 – Cover the Attic Access
To keep fiber off the attic access, cover the access with a cardboard. To do this, measure the size of the attic access and then cut the cardboard to fit into it. Use adhesive tape to keep the cardboard in place.
Step 3 – Block the Recessed Light Fixtures
If you have recessed light fixtures in your attic, block the fixtures with the using a metal flashing. When putting on the metal flashing, be sure to keep at least three inches of airspace between the flashing and the light fixture. The metal flashing will keep fiber away from your recessed light fixtures.
Step 4 – Use Rulers to Guide You
To know if you have reached the optimum insulation depth, put some rulers in strategic places. You can use adhesive tape to hold the rulers in place.
Step 5 – Put on Protective Gear
After getting your attic ready, put on your long sleeves, long parts, safety eyeglasses, dust mask, gloves and hat.
Step 6 – Install the Blow in Fiberglass Insulation
To install your blow in fiberglass insulation, fill the hopper of the blower with cellulose insulation then hold the hose parallel to the floor. The insulation should fall 10 to 12 feet away from where you are standing.
When installing the insulation, start at the farthest end of the attic and methodically work towards the center. Check the depth of the insulation from time to time and make sure that you do not cover the eave vents. If you accidentally cover the vents, use a putty knife to gently crape off the insulation.
You may need to refill your hopper from time to time so check its content every few minutes. For best results, do not let the content of your hopper fall below its minimum requirements.
Step 7 – Remove Covers
After applying your insulation, remove the covers on the attic access and the recessed light fixtures.
 forum activity
