Installing Metal Ceiling Tiles Step-By-Step
Installing metal ceiling tiles can add a decorative touch to any room especially if restoring a classic home where imitating a particular style – like Victorian – can be accomplished. The use of metal tiles allows a return to an original look or can add a unique appearance to a modern design. Follow these instructions so you will have a successful do-it-yourself project.
Materials Needed:
•Metal ceiling tiles
•Ladder
•Nail gun
•T-shaped brads or decorative nails
•Chalk line
•Safety goggles
Step 1 – Select the Tile
Search for a tile that are decorative and colorful. A good idea to save time instead of driving all over town is to search the Internet looking at samples, comparing prices. Once you’ve narrowed down your choices to a manageable few, find a local dealer that carries these metal ceiling tiles. They come in different materials including steel, aluminum, copper, brass and tin. Make sure you are making price comparisons “apples to apples.” The price will vary according to metal type. Take your ceiling measurements with you when visiting your local home improvement center to select your metal ceiling tiles. The employee there will help you calculate how much tile you’ll need to complete the job. Always include a 10 to 15 percent buffer for waste and future repairs. Tiles typically are constructed in two sizes – 24-inch squares or 24 X 48 inches. You can find larger tiles at 24 X 72 or 36 X 72 but these are usually destined for industrial settings. They can be used in a home but are harder to work with.
Step 2 - Mark Ceiling
Use a chalk line to mark off four equal sections of the ceiling. Make sure the intersecting lines are at the center of the ceiling.
Step 3 – Start at Center
Where the chalk line intersects, place one tile in each corner to begin your installation. You should have four tiles installed.
Step 4 - Use a Nail Gun
Attach the tiles to the ceiling using a nail gun for easy application. Although T-shaped brads work best on a project like this, you may want to use decorative nails to add a little extra to the ceiling look. Either cut a regular tile to fit any gaps or use filler tiles for this purpose. Tiles can be cut to fit in place using a good pair of tin snips. Make sure when nailing each tile in place that you have them aligned properly. Try to work as close to the ceiling as possible to ensure accuracy. Never work extending your arms way above your head trying to hold a tile in place while nailing it. If possible, work in a two-person team to successfully complete the project where one holds and one nails.
Tips to Remember
•Many metal ceiling tiles are shipped with protective films covering each individual tile. Make sure to remove these before installation.
•Always wear safety goggles when using power tools and or nail guns.
