Login Error
Close
Installing Motherboard Drivers
by DoItYourself Staff
Installing motherboard drivers is one of the most important things you can do for your computer. If your motherboard driver is not updated regularly then it may become incompatible and may not recognize the operating system on your pc for example. This means software you have installed not being used and not functioning correctly. Many suppliers will provide motherboard drivers that are compatible with relevant operating systems. By doing this you will keep up to date with the latest technology available for your computer. So in this sense these drivers are extremely vital for the continued well being of your computer and its programs.
Step 1: Determine the Type of your Chipset
Firstly, you need to ascertain what sort of chipset you have in your computer. One of the most popular and well known is Intel. Each type has its own motherboard drivers and you need to know which one you need to install before actually going through the process in case you install the wrong one for your machine and operating system. If you do this then your pc may not work properly.
Step 2: Install the Motherboard Drivers
If you have an Intel chipset for your computer then this is excellent as these particular ones offer great stability and endurance. They are also compatible with a lot of the operating systems you can have. The first thing you need to do is download the latest information for the particular driver and then click on the setup executable file to start the installation. Next you will need to follow this installation wizard, which is simple enough, and then get the driver installed. When this is done then you should restart the computer to apply the changes. The reason why it is vital to restart the computer to make the changes work is because drivers are all standard installations of Windows programs.
Step 3: Set up the Motherboard Drivers
Once you have installed the Motherboard Drivers on your computer and then restarted the machine you should right click with the mouse on "My Computer" menu item and select "Properties". Once in the properties section you need to choose "Hardware" from the menu and click on the "Device Manager" option. In here you can look at whether the driver has been installed correctly and works correctly. If you see the particular driver in the list then it should have been installed okay and work for your computer. Then you just need to test it out and see if it is okay.
Importance of Installing Motherboard Drivers
The main reason for installing motherboard drivers is to keep up to date with new programs and technology on your computer like new software. If serial numbers change, for example, then the existing drivers could well be incompatible with your pc. Each device needs its own programs to work okay. New drivers also allow you to connect to more hardware than before. If you have the correct drivers installed, your machine will be far more effective and the drivers will match the hardware and software installed.
 forum activity
