Installing Outdoor Handrails
what you'll need
- Prefabricated handrail set
- Mounting brackets
- Drill and masonry bit
- Concrete adhesive
- Lag bolts
- Stud finder
- Silicone
- Measuring tape
- Gloves
- Safety glasses
Outdoor handrails are safety features installed along stairways to provide support and stability while walking. Even in the absence of stairways, outdoor handrails are extremely important in areas that are constantly wet or covered with snow. Handrails also help disabled and elderly people to roam around freely without any human support.
In many countries, it is mandatory to install outdoor handrails where a significant amount of public movement is involved. Most of the stipulations regarding handrails are related to their size and other safety features. This is necessary because properly designed and erected handrails bring down the number of injuries caused by unguarded stairways.
Handrails are usually made from stainless steel, wrought iron, aluminum, vinyl, wood, brass or glass. Consider factors like budget, utility and aesthetics before deciding the type of material you want to use for creating outdoor handrails. If the handrails are being installed at a public place, contact your local municipality and get the design approved from them. Follow the procedure given below to create outdoor handrails:
Note: Since handrails come in various shapes and sizes, this article describes a generic procedure of creating outdoor handrails, ignoring specifications. It is also assumed that the handrails are being installed on concrete stairways.
Step 1: Design Outdoor Handrails
Handrails can be installed as posts or can be fitted to walls. Taking into consideration all these factors, create a design that can be passed on to the fabricator or manufacturer.
Tip: Outdoor handrails with attachment hardware are easy to install and easily attached to the wall or the bottom of rail.
Step 2: Clean the Surface
Neatly clean the surface on which outdoor handrails are to be installed. This can be done by using a pressure washer. This will wash away apparent debris, grime and stains.
Step 3: Mend Broken Surface
If any part of the surface is broken or loose, mend it using concrete adhesive or masonry bit.
Step 4: Locate Studs
Pinpoint wall studs using the stud finder and mark it up with chalk. Keeping the stud in center, mark points according to design and layout of the handrails.
Step 5: Install Mounting Brackets
Once all the markings have been made, start installing the mounting brackets according to the layout. Drill holes in the wall or stair landings according to the size of mounting brackets. Draw lug nuts through them and reinforce them with silicone.
Step 6: Insert Posts
After properly installing the mounting brackets, insert the handrail post in each one of them. Attach the handrail strip with screws to the handrail posts.
Important Tips
- If the outdoor handrail is being installed in a public place, make sure the designs are approved by local authorities.
- Outdoor handrails in open spaces should not be made out of metal.
- It's a good idea to have a helping hand, as there is a lot of work involved in outdoor handrail installation.
- Don't work without safety glasses.
