Installing Pool Deck Paver Lights: 2 Tips
If you want to add extra lighting around the side of your swimming pool, then you should consider installing pool deck paver lights. These are small lights which are built into paver brickwork, allowing you to build a small patio or pathway incorporating the lights into the design. They allow you to have better lighting in your garden. When installing pool deck paver lights, there are a number of things that you should consider.
Positioning the Paver Lighting
When installing your pool deck paver lighting system, you should consider the total area you need to cover with light. These are not very big or strong lights, so you need to place them strategically to get the most from them. A good idea is to turn on the lights and then position them before you install them so that you can see how powerful the lights are and how best to place them.
Avoiding Water Damage
All types of lighting are vulnerable to water damage, and this can have a serious effect when it comes to lights that are fitted near a pool. One solution to this is to choose lights which are specifically designed to be fitted around a pool.
