Login Error
Close
Installing Radiant Barrier Attic Ceiling Insulation
by DoItYourself Staff
what you'll need
  • Radiant barrier foil
  • Foil tape
  • Stapler
  • Utility knife
  • Tape measurement
Radiant barrier attic ceiling insulation is a type of ceiling insulation that is used to reduce heat loss and lower your energy bills. This type of ceiling insulation uses a reflective aluminum or foil sheet that can be used in all types of buildings such as residential homes, commercial and industrial buildings.
Installing radiant barrier attic ceiling insulation in your home can be accomplished by following the steps provided below in this how-to article.
Step 1: Purchase Radiant Barrier Foil
You will need to purchase radiant barrier foil sheets from a home improvement center or other retailer that carries this type of insulation product. It would be helpful to take measurement of the ceiling attic to purchase the precise amount of insulation needed for this project.
Step 2: Place and Cut the Foil Sheets
Place the sheets of the radiant barrier foil insulation in your attic against the wall frames, using a stapler to affix the sheets to the stud. A utility knife can be used to cut the foil as you manipulate it to fit your wall.
Step 3: Cover Seams
Any seams that are developed during the installation of the insulation can be covered using radiant barrier foil tape that is designed specifically for this type of installation.
 forum activity
