Login Error
Close
Installing Slate Wall Fountains
by DoItYourself Staff
Slate wall fountains are designed to bring out the natural beauty on any part of the home. Wall fountains not only add beauty and class to your home, but they also add a degree of sophistication to any interior decorating motif. There are a lot of slate wall fountains available, and you could choose from a wide variety of types and designs that are perfect for your home. Studies have shown that the sound of cascading water will not only help improve your mood, but is relaxing as well, increasing the serenity of any space. Chinese feng shui also recommends adding a wall fountain or any type of water decoration to increase the level of good chi inside your home.
Choosing Slate Wall Fountains
When choosing a slate wall fountain for your home, first determine a size that the room can handle, but is not too small. This will prevent the arduous task of redecorating the space just to accommodate the wall fountain. A rough estimate of the proper size is enough for most, but using a tape measure is good insurance to assure a proper fit in your intended space.
Electrical Outlets and Connections
Carefully planning the electrical connections will also make the installation process easier to bear. Remember that the best location for the electrical outlet should be at the back of the fountain assembly. This not only serves a safety purpose but an aesthetic purpose as well. The beauty of your wall fountain will be spoiled by the appearance of unsightly wires hanging in and around the fountain. Make sure to have an electrical outlet ready in the place of installation. When in doubt, it is always best to consult an electrician to have an electrical outlet wired and ready before the installation process.
If your wall fountain is equipped with halogen lights, then a separate switch for the fountain and the lights is ideal to save electricity. By this way, you have the option to turn off the lights while still retaining the calming sound of falling water.
Slate Wall Fountain Installation
This installation requires no special tools or talent to properly undertake. All it takes is a few DIY skills and an eye for detail. It does help to have a few basic tools at your disposal to facilitate the installation process. It would be best to have a screwdriver, a drill, masking or electrical tape, a hammer and a pencil to make the installation process easier.
Slate wall fountains also have brackets that need to be screwed on the wall. Use the brackets. Never settle for any type of material when securing the fountain to the wall.
You could install the wall fountain by yourself, but two people would be best for this procedure. Have a friend or neighbor help you during installation.
 forum activity
