Installing Window Air Conditioning
Installing window air conditioning is an affordable way to cool off in the hot summer months. There are many different type units that can be purchased and all at an affordable rate.
What to Know Before Installing Window Air Conditioning
You should determine the area that needs to be cooled and purchase a unit that is sufficient enough to handle it. Not all units are the same size so before installing window air conditioning, measure the windows you want to place them in.
How to Install Window Air Conditioning Units
Installation of a window air conditioning unit is fairly simple. The unit should come with mounting brackets for your window that are easily installed. Once the brackets are in place, the unit can be slid into place. Pull the window down to the top of the unit and attach the drainage hose to the outside.
You may need to caulk areas that are not sealed when you install the window air conditioning.
