cancel
Find Qualified
Local Contractors
Select Service:
Enter Zip:
community forums
Installing Window Trim
comments
By Brian Simkins
< Back to Window Trim Tools, Materials and Terminology
There are two primary methods of installing window trim. The first is called a wrap-around style. It is constructed by placing an identical piece of trim on all four sides of the window frame. In reality, you are "wrapping" the trim all the way around the window. This style is most often used in small rooms. It doesn't leave bulky pieces of trim protruding into the room, by emphasizing the glass in the window instead of the trim, it can make the room appear a little bit bigger than it actually is. Here's how it's done.
  1. Measure the top of the window frame from inside edge to inside edge.
  2. Add 1/4" to that measurement. This will allow you to create a reveal of 1/8" on each side when you install the piece.
  3. Using your miter saw, cut one end of a length of trim to 45 degrees.
  4. Measuring from the bottom (or the shortest) edge of the angle you just created, measure the distance that you determined in step #2 and make a mark.
  5. Adjust your miter saw so that the next cut will be a 45 degree cut that results in your mark being the short end of the angle.
  6. Hold the piece in place to make sure that you figured the reveal correctly. Level the piece and then secure it with a few finish nails. Don't drive a bunch of them yet, as you may have to remove it to make some slight adjustments if the window isn't completely square.
  7. Repeat the process for each side, and then the bottom. Once every piece is in place and you are happy with each miter, drive a nail on the inside and outside edge of the face every 8" to 12".
The second way to install window trim is by utilizing an apron and a stool. The process is similar to installing a wrap-around style casing except for the bottom, where you will use the stool. You can buy stool material already milled from your local lumber yard or home improvement retailer. The stool has a groove milled into the bottom so that it will rest on the inside edge of the sill.
The stool and apron installation will most likely be used in a home where the woodwork plays a predominant role in the decorative feel of the house. Stools of varying sizes can even be used as small shelves, and the presence of a stool and apron helps give a room depth and texture. Here is a step-by-step break down of how to install the stool and apron.
  1. You will need to cut the stool to fit each individual window. Start by measuring the distance between the insides of the window frame.
  2. Next you will need to account for the reveal, typically 1/8". Double that amount, since there is a reveal on each side of the window, and add a total of 1/4" to your stool width.
  3. The next measurement to add is the width of the casing that will be on the side of your windows. You are going to want the stool to extend at least to the edge of the casing, so add the width of the casing twice, as there will be casing on each side.
  4. The last measurement to add is the horn. This is a distance that you determine based on how you want the window to function and to look. Typically the horn is 1/2" to 3/4". Remember to add it twice.
  5. Once you have added all of those measurements together, cut the stool stock to length.
  6. After the overall length is correct, notch the stool so that it will slide around the casings and the window frame. Take the measurement between the window frames and mark that distance on the stool. Then measure to see how deep the notch needs to be. Lay this out on the stool and cut the notches with a jigsaw.
  7. Once the stool is cut to fit, secure it to the sill with finish nails.
  8. The side and head casings will be installed just like they were in the wrap-around style.
  9. Once the side casings are in place, you can create the apron. Measure across the window from the outside of the casings. Using this measurement, cut an additional piece of casing and install it underneath the stool. This decorative piece will serve as the apron, and will also lend some additional support to the stool. After the apron is nailed to the wall, drive several finish nails through the sill and into the apron to secure it.
If you do not have access to a miter saw, there is another way you can form the joints on your window casings. By using a butt joint, you can create a clean and neat looking corner. This is formed simply by "butting" the ends of the casings into each other. One key thing to keep in mind, though, is that profiled casings will not work for butt joints. The casing must be flat and of a uniform height.
If you really want to use a profiled casing and don't have the ability to miter the corners, there is one solution available to you. You can use plinth blocks, sometimes called rosettes, at the corners. These are small squares or rectangles of wood, often decorated with a floral pattern or a bull's-eye, which allow you to butt the casing right up against it on both sides. This plinth block eliminates the need for any difficult joinery. Simply set the blocks at each corner so that they leave the appropriate reveal and then measure the distance between them. Cut the casing to that length and install.
Finishing
The final steps are that ones that will give your window trim an air of sophistication and make it look like quality woodwork. Take the time to get your nail set and hammer and go over each piece of trim in detail to make sure every nail head is set.
Once the heads are all set, you can then go over them with wood putty and fill the holes. If you are painting, you can use a lightweight spackling compound, which is easy to sand and dries very quickly. If you are going to stain and varnish your trim, then you will need to find a wood putty that matches the color of the stain you are going to use.
After the wood putty or spackling compound has dried, use a 150 grit sandpaper to buff it smooth, and you are ready to paint, stain, or seal.
As you can see, the biggest challenges that come with choosing to install your own window trim is deciphering some of the jargon. Once you are able to break through that, and if you are comfortable doing math with fractions, there really isn't anything standing in the way of you doing your own woodwork.
Brian Simkins is a freelance writer living in Chicago. He enjoys using his 14 years of home improvement experience to educate and equip new home owners.
© 2007 Doityourself.com
member comments
Related Articles
Glossary of Remodeling and Construction Terms
Glossary of Remodeling and Construction Terms... read more
How to Build a Window Cornice
A step-by-step guide to building a wooden window cornice that can be used to add... read more
Using Wallcoverings to Create Cornices
How to use wallcoverings/wallpaper to create cornices... read more
articles we like
Electric Socks
Electric socks have come a long way since the 1950’s when they were first invented... read more
Compost Build
Generating a compost build has been done for many years, but it seems to be... read more
What Is a Second Home?What Is a Second Home?
The following article discusses the pros of owning a second home and how to begin... read more
sponsored articles of the day
diy centers
