cancel
Job type :
Zip Code :
community forums
comments
Insulation Walls
Some form of insulation walls are required by building codes for just about any structure imaginable. Properly insulating walls is essential for a number of reasons.
Types of insulation walls
There are several types of insulation walls that are used commonly in residential, commercial and industrial construction. They include:
  • Standard insulation – Insulation walls that fall into this class will have standard fiberglass sheets in between the studs and behind the drywall. Insulated foam spray may also be used.
  • Insulated wall panels – Some construction may call for the use of special insulated walls that come in ready-made panels. These can replace the need for fiberglass or augment its effectiveness.
  • Fire rate – Some insulation walls aren’t meant to hold in heat or cold. Instead, they are designed to sop fire in its tracks.
Reasons insulation walls are important
Making sure insulation walls are properly suited for the project at hand is essential for more reasons than just meeting code. When insulation walls have the proper rating, they can:
  • Reduce fuel/electricity consumption – Insulation walls can keep buildings cooler in the summer and warmer in the winter. The end result is lowered consumption.
  • Comfort – Insulation walls help regulate temperatures in a building, which can improve overall comfort.
member comments
Did-it-myself Projects
updated by LessWire
did this on 4/28/2009
3 Bedroom 1 Bath Addition
updated by SKHK1
did this on 4/12/2008
Two Room Addition
Decorating For Thanksgiving
sponsored articles of the day
