Interior Design Tips with Oak Engineered Flooring
Working with oak furniture or oak engineered flooring is nice, because oak is a very common type of wood. Depending on the tint and style of your oak engineered flooring, you can use different design elements to make the room feel cozy and warm or make it look modern and make colors pop.
Different Colors of Oak Engineered Flooring
Oak is a lighter-colored wood. Its tints tend to range from golden to a reddish color. More modern versions of oak flooring can have gray tint which make them go well with bright colors. Oak is one of the most common types of wood used for floors and furniture, and it’s one of the most affordable types as well. There are a few steps you can take to make sure all of the oak in your room will match.
A light sanding and oak wood stain can make the different pieces in your room go together better. If you purchase unfinished oak engineered flooring, you can purchase the exact color of stain you want to use on both the floor and furniture. This way you can be sure that the floor will match the other pieces of furniture in your room.
Using Oak Engineered Flooring to Make a Room Look Bigger
Dark floors tend to make rooms look darker and smaller than light floors. For example, a room with walnut floors might look smaller than a room with oak floors. Make sure your furniture is not darker than the flooring, because this can also make a room look smaller. If you paint your walls a bit darker than the floor, it will really pop and can make the room look more spacious.
Design in the Oak Engineered Flooring
Modern flooring comes with a number of different options for having decorations in the actual wood flooring. It has become common to have accents or focus points. These designs on the floor can be in corners of the room, on staircases, or in the middle of smaller rooms, such as bathrooms and foyers. Another design option is to do stenciling on the wood flooring. If you purchase unfinished oak, you can stencil a design before sealing the floor, and you’ll have a unique look that is all your own.
Working with the Tones of Oak
When working with the tones of oak to plan the color scheme for oak engineered flooring, there are a couple of things to keep in mind. To have a color scheme that matches your oak flooring, you’ll need to determine the tone of the wood. Red or golden oak flooring can be matched with warm colors and earth tones. On the other hand, you can use a color wheel to find the complimentary color of the tone of wood your floor has and use that color to offset the oak flooring. For example, if you have red-toned oak floors, you can use different shades of green in the room. Gray oak flooring can be used with almost any color, especially very bright ones.
