Login Error
Close
In-Wall Wall Insulation: Pros and Cons
by DoItYourself Staff
There are many options for choosing wall insulation. Some of those options can be very hard to understand and choosing the best insulation for your walls can save you time and money. Wall insulation can be installed professionally or if you have the right knowledge you can do it by yourself. Either way it will be a great investment to your house and it is well worth the money.
Rigid Foam Insulation
One common type of wall insulation is rigid foam insulation. This insulation is a pressed board and is applied directly in the wall. It reduces heat loss through the wall and it covers the entire wall creating more protect against any heat loss. This type of insulation is a fire hazard and can be dangerous if not covered. If rigid foam in used it will need to be covered and not left as a final finish to your wall.
Insulated Concrete
Another type of wall insulation is insulated concrete which is used for newer buildings. This insulation is hollow concrete blocks that are filled with foam insulation. These blocks increase a wall’s thermal resistance which causes the wall to insulates and prevent from heat loss. This is not that common in houses for wall insulation and is used mainly in newer buildings.
Loose Fill Insulation
Loose fill insulation is another common type of wall insulation. This is usually blown in walls and hard to reach places. It is recommended to get a professional installer for this type of insulation as it can be very dangerous to inhale this type of insulation.
Blanket Insulation
This is the most common type of insulation used in new homes. This is used for wall insulation and it is one of the easiest insulation's to install. It comes in the form of blankets and you layer it in the wall studs of your house. You can get it in a standard size that will fit most wall studs and makes the installation job fairly easy. The blanket insulation is the most common and is used in new homes everywhere. This insulation is available with a facing so that is creates a barrier against heat loss. The blanket is also available without a facing if you prefer that as well.
Overview
These are just a few types of wall insulations and a few pros and cons of each. There are many types of insulation available on the market. The best way to choose what is right for you is to start by what you need in your area that fits your climate. If you live in high heat or really cold weather you will need something that is fit more for your climate. A few options to consider are your budget, where you live, and how much you will need. Go from there and you should be able to find the right insulation for you. Insulation will pay for itself if you take the time and effort to get what is right for your home.
 forum activity
