Login Error
Close
Ironing a Button-Up Blouse
by DoItYourself Staff
what you'll need
  • Iron
  • Ironing board or flat surface
  • Towels (Optional)
Ironing a button-up blouse is a very easy procedure. Follow these steps to make your blouse look its best.
Step 1 - Surface
If you have an ironing board, that will help you only iron small sections at a time. However, a table will work, or even the floor. Just make sure you place a layer of towels on the table before ironing.
Step 2 - Heat Iron to Temperature
Set the control on the iron to the specific temperature and let it heat up for a few minutes before using it.
Step 3 - Lay Shirt Flat
  • Lay the shirt flat on the ironing board and start with the sleeves.
  • Move the shirt around until the sleeves are flat on the board.
  • Run the iron down the length of the sleeves for a few swipes.
  • Move the blouse until the other sleeve is flat on the ironing board and repeat the ironing.
Step 4 - Iron Front of Shirt
  • Leave the shirt buttoned and lay it flat on the ironing board.
  • Run the iron along both sides and then in between the buttons.
  • Simply slide the edge in between the buttons and make sure the seam is flat and unwrinkled.
Step 5 - Iron Back of Blouse
  • Turn the shirt over and run the iron lightly over the back of the shirt.
  • Pay special attention to the bottom of the shirt.
 forum activity
