Login Error
Close
Is Baking Soda Drain Cleaner Effective?
by DoItYourself Staff
Baking soda drain cleaner is a good cleaner to use because it doesn't have harsh chemicals. Baking soda is sodium bicarbonate, and it is a natural occurring substance that is found in all living things. It helps regulate the pH balance.
What Is It Made of?
Baking soda is made from soda ash and is mined in the form of an ore called trona. Once the soda ash is dissolved into a solution, carbon dioxide bubbles and forms and sodium bicarbonate precipitates out.
How It Cleans
Baking soda is safe and effective to use for kitchens and all types of bathroom surfaces. It addition, it can be used as a scouring powder because it won't scratch shiny surfaces. It can lift dirt and is good in removing stains.
It Deodorizes
Baking soda drain cleaner absorbs odors from stinky foods which makes this perfect to use down the drain. It can eliminate odors before they occur and even continues to deodorizes when it is mixed with water. It works by absorbing odor causing smells from foods and also sanitizes.
 forum activity
