Login Error
Close
Is It Cheaper to Replace Stucco Siding with Brick?
by DoItYourself Staff
Replacing stucco siding with brick will not generally save you a lot of money. Brick is one of the most expensive types of siding that you could purchase for the outside of your house. Replacing your existing stucco with brick can provide you with several benefits such as improving the look of the exterior and also improving the insulation properties of the wall. However, this job should not be done if you are trying to find the least expensive alternative. Stucco, vinyl and wood are all cheaper than brick siding for your home.
 forum activity
