Login Error
Close
Is it safe to cut cracked mosaic glass tiles?
by DoItYourself Staff
In cutting mosaic glass tiles for installation, you should avoid attempting to cut tiles that are already cracked. With the exception of a wet saw, almost any type of glass tile cutter will place pressure on the tile and it is almost certain to break a tile that is already cracked.
Safest Mosaic Glass Tile Cutters
Even the best glass cutter can break, crack, or shatter a mosaic glass tile if it is used improperly. To achieve the best results in cutting your mosaic glass tiles, avoid trying to cut cracked tiles and use a mosaic glass tile cutter.
 forum activity
