Login Error
Close
Is Masonry Paint Good for Garage Floors?
by DoItYourself Staff
A masonry paint is a specifically-formulated paint, commonly recommended for painting domestic surfaces called masonry surfaces. A masonry surface refers to all kinds of porous surfaces, including surfaces made of mortar, concrete, brick or cement. Domestic masonry surfaces include the bathroom and garage. The porosity of such surfaces creates the problem of greater moisture seepage. This is why masonry paints are primarily used as a surface treatment option, i.e. the paint coats the porous surfaces in a comprehensive manner, sealing–out the moisture. Since most garage floors have a concrete-based preparation, using masonry paints for coating the garage floors is a good idea. Some other benefits of using masonry paints includes:
Increased Durability
Masonry paints form a durable coating on the garage floors. Since garage surfaces are typically high-usage areas, the paint prevents daily, wear and tear, prolonging the life of such surfaces. Specific masonry paints are retailed for garage floor application. These paints are infused with industrial-strength sealants that last for decades.
Enhanced Safety
Smooth concrete surfaces are inherently slippery. A garage is often filled with tools and other potentially-dangerous objects. A slip in the garage can prove to be fatal. To minimize such safety hazards, using masonry paints is recommended. Special masonry paints are retailed as textured floor paints that neutralize the slippery nature of garage concrete floors.
Easier Maintenance
Paints for garage floors should have a greater immunity against staining, scraping and scuffing. Epoxy-based and oil-based masonry paints create a rustproof layer upon the concrete floor that doesn’t stain or scratch easily. Masonry paints aren’t vulnerable to most chemicals found in domestic garages.
 forum activity
