Keep a Drain Clean to Prevent Clogging
If you frequently have problems with clogged sink, shower and bathtub drains in your home, it may surprise you to learn that you can effectively prevent clogs by simply keeping your drain clean. If you administer regular cleanings to your home's drains, you may never have to worry about stubborn clogs again.
Hot Water Cleanings
One of the simplest and most effective ways of keeping a drain clean and clog-free is administering a weekly hot water rinsing. There are 2 ways to go about this: Either manually pour some boiling water down a drain or, if the drain is beneath a faucet, run some very hot water directly into the drain. This will help loosen up any dirt, grime, hair or mineral deposits, ultimately washing them down the drain before they have a chance to accumulate and give way to the formation of a clog.
Frequently Clean Your Drain Trap
Another easy way to keep a drain clean and safe from clogs is to frequently clean your drain trap. This pertains specifically to bathtub and shower drains and entails wiping any hair, dry or soap scum off the drain trap whenever you have finished bathing. If left alone, these well-known clog-causers will eventually find their way into your drain. This simple cleaning task will require no more than a minute of your time and can go a long way in preventing drain clogs.
