cancel
Job type :
Zip Code :
community forums
comments
Keep a Stained Glass Fireplace Screen Clean
The key to keeping a stained glass fireplace screen clean is to wipe it down frequently rather than allowing dust to accumulate to the point where you have to use a liquid cleanser. If fireplaces and wood stoves are a regular source of heat in your home, you'll have to clean the stained glass more often.
For seldom-used fireplaces, all it takes to clean the stained glass screen is a soft, dry cloth. However, if a layer of dust has accumulated, it may be necessary to dampen the cloth lightly with plain water first.
Stained glass fireplace screens that are exposed to heavy use or those that have never or rarely been cleaned may require more than water. First, apply a lemon oil-based furniture polish to a soft, dry cloth and wipe the screen gently. If the furniture polish does not do the trick, you can try a nonionic detergent, rubbing alcohol or gentle solvents.
Never apply a cleaning product directly to the surface of the stained glass screen. Always apply the cleanser onto a soft, dry cloth first. Avoid harsh chemicals and abrasive cleansers as well as any type of ammonia.
member comments
Did-it-myself Projects
updated by FelipeBR
did this on 9/22/2009
Iphone Bus Holder
updated by SolarPanel
did this on 8/29/2009
Home Build Solar System
updated by dorfin
did this on 3/30/2009
Recoil Starter Repair
Decorating For Thanksgiving
sponsored articles of the day
