Login Error
Close
Keeping Patio Tables and Chairs Splinterless
by DoItYourself Staff
The patio, tables, chairs, and other wooden furniture may split or splinter when exposed to harsh or humid weather conditions. The easiest way to avoid this problem is to use non-splintering materials instead.  Aluminum and PVC are both excellent choices for any climate zone and tend to be lighter than wood, making the furniture easier to move about as needed. If wood is the only option use teak, which is renowned for the fact that it does not splinter.
Types of Patio Furniture
Avoid bamboo furniture, as it splinters easily under the right conditions. Wicker doesn't splinter, but it may warp or split. Common materials such as pine and oak need to be completely finished to avoid splintering and cracking in extreme weather. Aluminum is a popular material, but you should take care to purchase thick, sturdy frames, not ones that can be easily bent or broken. Plastic is fairly cheap, but it may become brittle in freezing temperatures, splitting and splintering at crucial joints. If using a synthetic material is preferred, PVC is one of the best solutions for outdoor patio furniture. Is not as susceptible to climate and weather as most others.
Pet Proof Furniture
Some pets chew or scratch at table and chair legs. Dogs do this to sharpen their teeth, and cats claw at furniture to sharpen their claws. To prevent pet damage, wrap the legs with plastic or rubber. It is not a visually appealing solution, but it is effective, and once the animal has been trained not to scratch or bite that piece of furniture the covering can be removed.
Weather Proof Furniture
Paint or polyurethane can be used to seal wooden outdoor furniture. To avoid the adverse effects of weather, use several coats of paint, forming a protective shell. Apply 3 to 5 coats of polyurethane to wood surfaces and be sure to cover the unexposed areas as well as those that are visible. The only way a sealant can work is if it provides a complete seal of the entire surface.
Patio Furniture Maintenance
Keeping your patio furniture in good repair will prevent splitting and splintering. Loose bolts or screws put stress on joints that often result in the wood binding or cracking. Missing fasteners could result in parts of the chair breaking completely. It only takes a few minutes to give your patio furniture regular maintenance. Your wooden patio furniture will last longer and have fewer problems.
Alternate Materials
Aluminum has many advantages as the primary material for patio chairs and tables. It is lightweight, which means it can be moved about with the seasons or your mood. It is also resistant to extreme heat and cold and will not rust if exposed to rain and high humidity. Similarly, molded plastic or PVC can be effective. Aluminum may cost considerably more than wood or plastic, but it is often the most dependable type of outdoor furniture material.
 forum activity
