Login Error
Close
Knife Sharpening Tools to Have in Your Kitchen
by DoItYourself Staff
You need a few kitchen sharpening tools to keep your utensils and equipment working properly. Dull blades can be dangerous, so it is best to sharpen your kitchen tools on a regular basis.
Leather Strop
A strip of leather is the basic material used to make a leather strop. This tool sharpens blades as the tool is drawn across the leather. An abrasive material can also be applied to the leather to use the strop as a polishing tool. A leather strop is usually hung on flat surface.
Sharpening Steel
These tools are made of a thin piece of steel attached to a safety handle. The kitchen is blade is pulled a number of times across the steel. This process sharpens the blade. Both sides of the blade must be pulled across the steel. .
Sharpening Stone
Kitchen blades are pulled across this stone much like sharpening steel. This rectangular shaped stone can be used dry or wet to sharpen kitchen blades
Electric Sharpeners
These devices use electric power to sharpen kitchen blades. The sharpener is turned on and the blade is run through slots in the device. The motor in the sharpener powers alloy, which grinds the blade while it sits in the slot. There are a variety of electric sharpeners available.
 forum activity
