Login Error
Close
Knowing When to Throw Away a Rechargeable Battery
by DoItYourself Staff
The rechargeable battery is a great invention that has saved space in landfills across the world. When standard batteries stop operating at top capacity, they are often thrown away into the trash. This was bad for the environment, and the rechargeable batteries helped to cut down on waste, as well as save money for those who used them. Still, even rechargeable batteries have a lifespan. They will not work indefinitely. Read onto learn when their time is up.
When to Dispose of a Rechargeable Battery
When your battery no longer holds a charge, it might be time to dispose of it. Before you make that decision though, check your charger to be sure that the contacts are clean. Dirty contacts on the charger can cause a battery not to charge properly. If you have had the battery for several years and you need to charge it more frequently, it might be time to change batteries.
Proper Disposal of a Rechargeable Battery
When you have determined that your rechargeable battery is at the end of its life, it is time to throw it away. However, you will not simply be able to throw it away into the trash or recycling at home. You have to take care to dispose of the battery properly. You can recycle the batteries through the mail, or you can find a drop off in your area that takes batteries.
 forum activity
