Knowing when to Use a Hydraulic Torque Wrench
An industrial type of bolting tool is a hydraulic torque wrench. They are very popular when it comes to heavy or industrial-type applications but can also be used for small industries or personal use whenever there is a need to tighten bolts and nuts easily and more conveniently. But when do you need to use a hydraulic torque wrench? Continue reading to find out when to use one for your project.
For the Toughest Bolting Jobs
Do you remember trying to loosen a nut in your car but you couldn't even turn it? Then after almost an hour you finally did but you still have a couple of other nuts to loosen up and remove. Then when you're down to a few nuts to loosen, your neighbor sees you and tells you he has just the thing you need. He takes his hydraulic torque wrench and you try it to loosen the remaining nuts, only now it took you just a few seconds.
Hydraulic torque wrenches are usually used for industrial or commercial applications. That's mainly due to the fact that this tool can handle the toughest bolting jobs. It's so simple to use yet it's very strong and durable. That's why if you find yourself having a hard time removing nuts and bolts of any given size and shape, a hydraulic torque wrench will surely do the trick. If you just can't unscrew something, make sure you get your hydraulic torque wrench and it will surely be unscrewed within seconds instead of minutes or within minutes instead of hours.
How can a Hydraulic Torque Wrench do the Job?
A hydraulic torque wrench is engineered for maximum capability that maximizes and optimizes their functionality and durability. It has competitive features that no other wrench can match up to. After all, it's the type of wrench being used for industrial applications. This torque wrench works in conjunction with the hydraulic hose attached to a power console. The pressure from the hydraulic power pack provides power to the torque wrench to ratchet with a push of a button, making it easy to loosen or tighten bolts and nuts. The high alloy steel materials as well as a well-coated body make it a strong and safe tool to use.
For Most Demanding Environments
Hydraulic torque wrenches are being used for the most demanding maintenance and assembly as well as turnaround environments in an industrial setting. The torque wrench has a couple of inbuilt features that's user friendly and built with high-technology standards all at a low-cost tool. What's more is that these types of wrenches guarantee long gasket life and ensure no leaks. The inbuilt designs offer it immense power as well as great performance allowing single operator, hands-free operation.
So remember, when a job calls for a tough, reliable and effective wrench to loosen or tighten bolts and nuts, a hydraulic torque wrench can just be the thing for you. Whether for autos or for your home, it can work on all sizes and shapes.
