cancel
Job type :
Zip Code :
community forums
comments
Lacquer
Lacquer is a clear or colored varnish that dries as the solvent evaporates. In many cases it is used as a curing process. The lacquer, when dried, creates a hard and very durable finish that will protect the material underneath.
You can find lacquer from a matte finish all the way to a high gloss. Lacquers, as well as shellac are both used as a protection coating for furniture and other items.
Lacquer Versus Shellac
Shellac is used in the same manner as lacquer for protection of the wood and other materials. Lacquer is actually more durable than shellac and can be easier to use, as well as is offered in many different sheen levels.
Always ensure that if you are using lacquer on wood or anything else that the area is completely clean and free of debris. If there is dust or other particles on the area to have lacquer applied you will have a bumpy surface instead of the smooth silk like surface the lacquer should create.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
How to Build a Shoe Storage Bench
sponsored articles of the day
