Login Error
Close
Laying Driveway Pavers: Five Tips
by DoItYourself Staff
Laying driveway pavers is a relatively simple task that you can complete with just a basic level of DIY expertise. Pavers are a relatively cheap method of providing a solid surface for your driveway and they can be put down in a series of intricate patterns to promote a unique visual effect.
Tip 1: Design
It is important to spend a little time on the design process. Many designs options are available to provide ideas while many more can be created for those who have an artistic flair. For instance, a colonial appearance can be gained by using brick driveway pavers. Alternatively, try breaking up the monotony of a plain driveway by adding a paver border in a different color. There are an infinite number of design options available for the homeowner to play around with before making a final decision.
Creativity is important when forging designs. A visit to a home improvement store would be helpful for assisting in this process and staff will be able to provide information regarding techniques that can be used when working on a design.
Draw ideas out on graph paper using colored pencils to represent the colors of the pavers. Spend time working out different designs and choose the one that will work best for the project at hand.
Tip 2: Ask for Help
Most paving jobs are completed with greater ease and can in less time if help is available. Get a couple of friends together for the pavement laying project and have a barbecue on it when finished!
Tip 3: Preparations are Important
Make sure the ground is ready for paving. Edging should be installed and the excavated area should be covered with ground stone and a layer of sand. Fabric can be placed on top of the excavated area to prevent weeds from forming and covered in an additional layer of sand.
Tip 4: Test Run
The pavers should be laid out appropriately before work begins. By laying them out, it is possible to see if tiles are missing or if the design isn't working the way that was first planned. It is better to change a few decisions at this point than when the pavers are set in place permanently.
Tip 5: Use the Correct Tools
A power saw will be necessary during the paver laying process for effective cutting to size. Trimmers and chisels may also be required. Be sure to learn the safety requirements for using these tools before beginning the project. It will be helpful to have a lump hammer available as well. Sometimes, this can be easier than using a power tool.
Tip 6: Laying the Pavers
The pavers should be laid so that they are slightly above ground level. Don't lay them too deep. It is important that they are laid flat and level so as not to cause a tripping hazard.
Laying pavers in an attractive way will help with both the appearance and value of the home.
 forum activity
