Login Error
Close
Lifting a Car Using a Trolley Jack
by DoItYourself Staff
what you'll need
  • Owners manual
  • A trolley jack
  • Jack stands
A trolley jack can help you lift your vehicle in order to get under it to make repairs or perform regular maintenance work. This device is simple to use and will make any repair job that requires your vehicle to be lifted much easier to complete.
Step 1 – Safety
Park your vehicle on a flat, hard surface. Be sure the ignition is turned off. Set the vehicle parking brake and position blocks behind the wheels. Read the owners manual provided by the manufacturer of the trolley jack before you begin.
Step 2 – Positioning the Trolley Jack
Position the jack under the frame rails of your vehicle.
Step 3 - Raising the Jack
Turn the handle of the jack in order to raise the vehicle. Continue raising the jack and the vehicle until they are at the height you need. Be sure to raise the vehicle slowly.  Position the jack stands under the rear or front axle.
Step 4 – Lowering the Jack
As you turn the handle again, the pressure of the trolley jack will be released and the jack will lower. Slowly continue the lowering process until the car is secured on the ground. Slide the jack out from under the vehicle.
 forum activity
