Login Error
Close
Lighting For Your Security Gate Entrance
by DoItYourself Staff
This article briefly explains how to take care of lighting for your security gate entrance.
Why A Security Gate?
You do not want any unauthorized intruder in your property. A good step in that direction is to install fencing. Outdoor lighting with the help of special outdoor light fixtures may also help to some extent. Next obviously should be to go for a security gate.
Major Factors To Consider
There are many types of security gates to choose from. You need to choose from them according to your needs. You should consider the width of the gate according to the vehicles to enter the premises. The types of gates could be chosen from swing or sliding. Material, cost and quality are some other aspects to consider. However, one aspect which makes your selection of gates complete is the lighting system of the security gate.
Lighting
The light system of the security gates are designed with the purpose of detecting unwanted intruders. Automatic lighting system is available which can be programmed to switch on or off at a predefined time. This system is not so efficient with detecting intruders. This system to some extent gives you relief from manually switching on the lights everyday.
The best lighting system for security gates is the lighting system designed with the technology of photosensitive sensors has the ability to be illuminated when it senses an intruder near the property. This system therefore scares the intruders away with the fear of being detected inside the property.
 forum activity
