cancel
Job type :
Zip Code :
community forums
comments
Lock Set
If you have a new or old door and you are trying to install a new lock set it may not be as hard as you may think. By just having a few simple tools and being able to measure accurately you can make it a very easy job. Not all of these steps will need to be done if the previous lock set is similar to the new one.Six Simple Steps to Installing a Lock Set
  • Use a spirit level to mark the top and bottom of the striker plate along with the opening and backset distace. Doing this will make it easier to line up. You may not need to do this if the striker plate is the same as the previous lock set.
  • Next you want to attach the guide for the lock set to the edge of the door. When doing this, make sure you follow the markings you previously placed.
  • You now need to drill holes for the lock set. Be extra careful that you don’t splinter the wood while drilling.
  • The lockset should have come with a template and router bit for cutting the mortise for the bolt plate. The plate should sit flush with the door edge.
  • Install the bolt and the plate.
  • Finish by attaching the lock set assembly.
member comments
Related Articles
Different Types of Door Locks
This article highlights the uses of 10 different kinds of door locks... read more
Troubleshooting Your Deadbolt Lock
If you are experiencing problems locking or unlocking a deadbolt lock, it is often better... read more
How a Door Lock on a Doorknob Works
For security purposes, most doors are equipped with one of two types of door lock... read more
articles we like
Screed
A screed is a flat, straight tool used for the purpose of leveling and smoothing... read more
AdhesivesAdhesives
This tool section introduces you to adhesives... read more
A Chance to Reverse Your Hair Loss
Guys, by the time you're 35, two-thirds of you will experience appreciable hair loss, according... read more
sponsored articles of the day
diy centers
