cancel
Job type :
Zip Code :
community forums
comments
Loft Insulation Made Easy
Loft insulation is crucial when considering your loft as a habitable area. This can seem overwhelming but the truth is that it is rather simple to do. Rather than pay a company to come in and do it, you can save quite a bit of money by doing it yourself. If after you learn how to do it, you still feel the need to get help, you can find insulation companies through any search engine.
Insulating
You will need to insulate the rafters as well as under the floor. Measure the rafters and cut the insulation to fit. Place the insulation between the rafters and seal it. Insulating under the floor will be done the exact same way. You will place drywall over the insulation jobs and then whatever paneling you choose. That is all you have to do. I know it sounds too easy, but it is easy.
Types of Insulation
There are many different types of insulation on the market and you will want to choose carefully and keep your finances in mind while you consider the choices.
Fiberglass
Pros: Highly efficient when it comes to keeping a room cool or warm. It takes a lot to ignite insulation.
Cons: Contains lots of small fragments of glass that can cut during insulating, so you will need to wear protective gear
Mineral Wool
Pros: Highly efficient when it comes to keeping a room cool or warm. Made from recycled materials and does not contain any added chemicals to fire proof.
Cons: Not quite as efficient as fiberglass in temperature control.
There are other different types of insulation, however the two mentioned above are the most commonly used. Prices for fiberglass insulation can range from 20 to 30 dollars per 40 square feet. Mineral wool is slightly more expensive and a little harder to find than fiberglass installation.
Choosing a Company to Insulate
If you have decided to work with a professional for your insulation needs, you should consider checking the classifieds for a handyman. This will save you a large amount of money. If you choose a handyman you will still have to pay for all of the supplies and make all decisions yourself.
Should you prefer a company who specializes in insulation installation, you can find a large variety of companies by using any search engine. If you are going to pay to have a company to come in and install your insulation, you might as well check on company reviews and reliability. Most companies offer a warranty with their service and you should really consider the benefits of the warranty. Once you have checked company reviews and reliability, it is time to compare prices and choose your company.
Consider the Options
If you choose to install the insulation yourself, you will save money but lose time. If you hire a company to do it, you will pay more, but you are saved time and if you get the warranty, you can also have peace of mind. Both options have their pros and cons, so they should be considered heavily before a decision is made.
member comments
Related Articles
Everything You Need to Understand About InsulationEverything You Need to Understand About Insulation
This insulation section provides useful information on everything you need to understand home insulation to... read more
Choose a Home DesignChoose a Home Design
Choose a Home Design by Jerold Axelrod... read more
Expanding Your Mobile Home
If you've lived in your mobile home for quite a while you could possibly be... read more
articles we like
Stained Glass Windows
Stained glass windows add a colorful, distinctive accent to a home while protecting privacy... read more
Vinyl Windows Price
Vinyl windows price per window is more attractive now than ever before. The price will... read more
Getting a Mortgage with Bad CreditGetting a Mortgage with Bad Credit
The following offers tips on how to get a home mortgage despite your imperfect credit... read more
sponsored articles of the day
diy centers
