Login Error
Close
Log Home Siding: Pros and Cons
by DoItYourself Staff
Log home siding is a popular choice for homeowners who seek a natural and rustic look. It consists of thin strips of real logs on the exterior walls of a home. However, log siding can also be installed inside the house. This creates a naturally attractive and warm appearance for your home. The high aesthetic appeal of log siding can also boost the value of your property. Below are 4 pros and 3 cons of this type of siding.
1.   Ease of Installation
One of the less complicated types of siding you can opt for is log siding. This makes it suitable for installation over various surfaces. It is much easier to accommodate duct work, wiring and plumbing with logs than some other siding materials. This contributes towards ease of installation and helps to keep labor costs down.
2.   Versatile
Log siding is produced from various woods with different grain patterns and textures. It is available in rounded or flat form. Various finishes are possible for corners and areas around windows and doors. You can install the siding vertically or horizontally which makes it compatible with various architectural styles. This allows you to achieve a uniquely attractive design for your home.
3.   Energy Efficient
Some of the most energy-efficient homes have log siding on their exterior walls. This is because logs improve insulation for your home. They help to keep the warmth indoors during winters and reduce on heating costs. During the summer, log siding helps to keep the interior cooler. The high-insulation properties of log siding gives you savings on energy costs in the long run.
4.   Aesthetic Appeal
Log siding is a great choice if you want to create a distinctly natural look for your home. The warmth and beauty of properly installed logs sets your home apart from others. It also boosts the value of your property.
However, there are also some drawbacks to log home siding:
1.   Cracks
Most types of wood siding, including logs, suffer from cracks. Frequent temperature changes contribute to splits in the wood. Fluctuations in humidity and moisture also contribute to cracks. If you don’t seal cracks in a timely manner they develop more extensively. Cracks are a perfect entry way for moisture. They also make it easier for insects, dirt and debris to get into your house.
2.   High Maintenance
Wood siding generally requires much care and maintenance if you hope to keep it in good condition for longer. You must clean the siding regularly and apply special treatments to guard against insect attacks and rot. You also need to stain or paint the siding periodically to protect it against the elements. Failure to regularly care for and maintain your log siding shortens its life span considerably.
3.   Mold and Mildew
Log siding is easily attacked by mold and mildew, especially if the wood isn’t well protected. Mold build-up tends to weaken the wood and triggers rot. Once one log is attacked, it spreads fairly fast to other logs. If not treated promptly, mold and mildew may contribute towards shorter longevity of your log siding.
 forum activity
