Long Term Effects of Efflouresence
Efflorescence is a problem that many homeowners have often have to deal with. This is a condition that occurs around grout or other products that are comprised of Portland cement. Here are some of the basics of efflorescence and the long term effects that come with it.
What is Efflorescence?
Efflorescence is a condition that is typically caused by the environment that leaves a white residue on masonry products. You will see a white film on the corners of the grout in between bricks or tile. The residue is salts that have been left behind while part of the mixture evaporated.
Long Term Effects
When you are dealing with efflorescence, there is a good chance that it will continue to occur. Even if you clean off the residue, there is a good chance that it will come back. You should be able to remove it with a bristled brush and possibly a mixture of hydrochloric acid and water. However, when you do this, it could potentially stain the grout permanently. If you have a dark colored grout, using any cleaning solutions on it to remove efflorescence could potentially lighten the color up. Therefore, this is likely to be an ongoing problem over the years.
