Login Error
Close
Maintaining and Caring for Your Steam Shower Unit
by DoItYourself Staff
A shower steam unit is a luxurious item that needs to be cared for and maintained in order to ensure long use. When a steam shower unit is damaged due to improper care and maintenance or neglect, then it will definitely cost a lot of money for repairs. A steam shower unit relies on electricity and a continuous supply of water in order to run smoothly. Therefore, it is important to check the power lines, the water supply pipes and the generator for any issues that may lead to damage. Also important is cleaning the inside of the shower unit because molds and mildew might grow. Here are ways to care for your steam shower unit.
Cleaning the Unit
Cleaning is an important maintenance procedure because it allows the unit to stay mold and stain free. Since steam showers produce moisture, they need to be cleaned and dried regularly. Stains and mold growth can be cleaned using all purpose cleaners or simple home remedies such as vinegar cleaning solutions. Inspect the surfaces of the shower unit to check for any eyesores and clean them using a rag dipped in cleaning solution. It is also a good idea to provide ventilation in the room where the unit is installed. Install an exhaust fan or open the windows every once in a while to provide air circulation. Allow the unit to be opened to make sure that the moisture escapes.
Changing Heating Coils
After long periods of use, heating coils in the steam shower unit may lose their efficiency and heating function. If the steam showers produce relatively lower amounts of steam, then the heating element or device may require cleaning or replacement. If so, have the heating element inspected and replaced if necessary.
Inspecting the Water Lines
Water is a very important factor in a shower. Therefore, the water supply pipes should be checked for leaks. Any leak in the water supply line can cause the steam generator to produce less steam pressure. This may affect the overall performance of the unit and may disappoint anyone who is taking a steam shower. Follow the supply pipes to check for leaks or any loose connections. Tighten the fittings if necessary and seal the leaks as soon as possible. Remember that shortage of water during the operation of the unit may cause damage to the unit.
Inspecting for Tightness of Seals and Joints
Silicone seals, water supply joints, valves, and nozzles should be checked at least once a year to ensure that they are tight and effective. If the silicone seals are loose, make sure to that they are replaced with new seals. Sealing the doors and the walls is not a very hard task and can be done easily even without the help of a professional. For nozzles, joints and drainage systems, they can be tightened or repaired using the most basic plumbing skills. If some of the parts of the unit fail to function, have someone repair or replace it especially if it is a delicate part.
 forum activity
