Maintaining Slate Tile Flooring
what you'll need
- Extra Slate tile
- Tile sealant
Slate tile flooring is often preferred by home owners due to its durability and cost-effectiveness. Owing to the nature by which the material was made, it is also capable of withstanding sudden impacts and is less penetrable to any form of liquid. To ensure that you enjoy all the benefits of slate tile flooring, here are some methods that you can make use of in order to maintain it.
Replace Chipped Tiles
Once you notice even the slightest cracks or chips, especially on the tiles that are found on the edges, immediately have that piece replaced. This should be accomplished as soon as possible, otherwise it will lead to further and greater cracks.
Wear something while Walking on the Floor
As much as possible, wear slippers or socks whenever you walk on your slate tile flooring. Oily secretions of the skin will actually attract more dirt and might create smudges on the flooring. Consequently, it will also stain the tiles and you likely not be so pleased with the result.
Constant Application of Sealant
For tile protection, you can add a coat over the tiles using various tile sealants. Re-coat or replace the sealant every once in awhile or when you notice that the coating has eroded.
