Login Error
Close
Make Kitchen Compost: Let's Breakdown Your Shopping List
by DoItYourself Staff
There are many people who are interested in reducing the amount of waste that is produced by the household and a kitchen compost system can help. However, not everything in a kitchen can be put in the compost pile, not even all food waste.
Composting is, however, one of the easiest ways to take steps toward a greener environment, and compost helps your own garden as well.
You’ll first need to set up a collection system for compost and then carefully note what items can go into a kitchen compost pile.
Make an Outdoor Pile
While you will collect food scraps in your kitchen, you will not want to complete the entire composting process in your kitchen. So you will need an outdoor bin.
This can be a simple wood structure, a round wood and wire structure, or any other combination that creates a contained place for your composing materials.
Another reason you need the outdoor pile is to add the “brown” compost material to your pile in order to have complete compost. Compost needs “green” matter like that found in fruit and vegetable wastes, but it also needs the drier, denser “brown” matter like leaves, hay, twigs and shredded paper. Brown compost material helps with aeration and is high in carbon, while the green material adds moisture and nitrogen and attract compost-producing microorganisms.
Choose a Kitchen Container
In the past, you may have had a bowl that you filled with eggshells and banana peels and other waste, and emptied it each night.
While this method may work, it is not attractive to many people. Powerful odors can emanate from an open compost bucket, and fruit flies are attracted to the container.
Now that composting is becoming a suburban and even urban way of life, there are other options. One is to use any tight sealing trash can as a compost bucket. This can work fairly effectively. You can use a diaper pail with a sealing lid as well.
For a smaller, counter top solution, look for a compost crock. These may be traditional crocks made of ceramic, or they may be aluminium or bamboo. What they have in common is a tight sealing lid and often a carbon activated filter in the lid to control odors.
Things to Collect for a Home Compost Pile
While commercial composting facilities can break down most any kind of organic matter, there are some you want to avoid in a home bin or pile.
First, never compost human, dog or cat waste. Although it seems strange because we deliberately put manure from other animals on plants and gardens, this type of waste doesn’t work as a fertilizer.
Things to collect in the kitchen include vegetable and fruit peelings, rinds, and leftovers, tea bags, eggshells, coffee grounds, bread, shredded newspaper (don’t pile in the stacked, dense newspaper, or it won’t break down).
Things to Avoid in a Home Compost Pile
The reason you should avoid most of the following items in a home compost pile is not that they cannot be composted, but the amount of time it takes for these items to break down.
Home piles work slowly, so these items tend to rot and/or attract rodents and vermin before they compost. This is a problem neither you nor your neighbors want, so steer clear of  items such as dairy products (cheese, sour cream, egg yolks, butter or yogurt), meats, lards, oils, meat bones, and meat scraps.
Avoid Chemicals
You want to include yard waste like grass clippings and bush trimmings in your compost pile, but avoid grasses treated with pesticides or any pesticide treated wood.
 forum activity
