Login Error
Close
Make Your Own Orchid Flower Arrangement
by DoItYourself Staff
what you'll need
  • Orchid Flower Varieties
  • Flower Shears
  • Flower Pot/Vase
  • Potting Soil/Mix
  • Wood Branches
  • Plant Tape
The orchid flower is a beautiful blooming flower that releases an aromatic fragrance when placed in a flower arrangement. Their petals are very delicately structured, and have a beautiful blend of colors and designs. Orchid flower arrangements make a unique addition to any home or special event. There are several different varieties of orchid flowers. With more than 30,000 different varieties to choose from, you will always be able to find the perfect combination for flower arrangements. You can make your flower bouquet from any of the varieties, although the most common would be the dendrobium orchids, cymbidium orchids, and vanilla orchids. Here are some valuable tips for making your own orchid flower arrangement.
Step 1- Assemble All Needed Items
The best way to get your orchid flower bouquet started is to make sure you have all the necessary items and equipment. Keep in mind that this flower arrangement will be in your home, at a special event, or someplace where people will see it. You should pick the most attractive pieces you can find instead of old, broken pots or vases.
Step 2- Create Orchid Potting Mix
If you have the time to make your own potting mix, you will need to have ground tree fern stem, ground bark, and some osmunda fiber. Mix these ingredients together and put them into the pot, or small vase. If you do not have the time, or can't procure these ingredients, you can easily pick up ready-made orchid potting soil.
Step 3- Carefully Cut Orchids
The hardest part of making your own flower arrangement with orchid flowers is the cutting of the orchids themselves. Use a sharp pair shears for this procedure and carefully choose the blossoms to cut. Snip the flowers on the stem about 8 to 10 inches below the blossom. Cut at an angle and do not break or tear.
You will want to have flowers grow back and tearing or breaking off the cutting will cause tremendous stress to the orchid. Orchids are delicate anyway, so any type of stress can cause the orchid to fail to produce more blossoms.
Step 4- Set in Potting Soil
Place the orchid stems into the potting soil, or water filled vase. Make sure that you do not cover the stem too much. Place in an area where the plant will get a little sunlight to keep the blossoms colorful.
Step 5- Tie Together with Tape
Using some soft plant tape, tie the stems together to make a formal arrangement and keep the flowers upright. Include some small wood branches, or other decorative elements, to give the flower arrangement a little more added touch.
Your orchid flowers should keep for up to a week and give you plenty of enjoyment in the sight of the colors and the fragrance given off. They will make a great decorative touch to any room.
 forum activity
