Login Error
Close
Making Laminate Flooring Waterproof
by DoItYourself Staff
Many homeowners are taking more and more home improvement projects into their own hands such as laminate flooring projects. Some homeowners are interested in making their flooring waterproof. Although laminate flooring can be purchased in a water resistant format, most experts will tell you that you should not attempt to do this on your own. There are several reasons for this and a few solutions to the issue of keeping the flooring dry and in excellent condition.
Waterproof Cracking
One reason that professionals do not recommend individuals attempt to make their laminate flooring waterproof is that the waterproofing materials will actually crack leaving cracks all along the floor. Additionally, because laminate flooring is typically a smooth surface, the waterproofing materials almost never adhere to the flooring. A lack of adherence can cause blistering and separation of the flooring and the dried waterproofing materials. This damage can be great and may be require replacement of parts or the whole flooring.
Change Floor Appearance
Another reason that many professionals do not recommend that individuals try to waterproof their laminate flooring is because it can change the way that the floor appears. The waterproofing agent can cause uneven strokes and clumping on the surface of the flooring. This is unattractive and in time could catch on things that pass over, damaging the flooring. This could cause a complete replacement of the flooring throughout and may be costly. Choosing to attempt to waterproof the floor may not show to be a poor decision at onset but at some point it will show as being a costly mistake.
Water Resistant Laminate
For individuals who are putting laminate in the bathroom area it is best to buy a water resistant laminate. In addition to the water resistance the laminate flooring can use an epoxy to fill in spaces around where the toilet is and the pipes from the sink going into the floor. This should seal the rough wood edges from any loose water keeping the laminate free from damage. One thing to remember when using the water resistant laminate flooring is that it is not waterproof, but water resistant. In addition, do not leave any standing water on the floor. The water will warp the wood and it will be very musky in smell. In addition, avoid leaving things like towels on the floor for any duration as they will leave marking on the floor.
Choose Right Laminate
Choosing the right laminate flooring from the start is vital to avoiding issues and floor damage. The popularity of laminate flooring in homes today is showing the product to be attractive and versatile flooring that will work well in nearly any space. The flooring is strong and is both classic and modern at the same time. The installation process is not complicated but does require an attention to detail and some time. This makes it one of the perfect home owner weekend projects of the times. Individuals choosing laminate flooring will have a large number of options available to them and will surely find one that fits their circumstance and taste.
 forum activity
