Login Error
Close
Making Patio Furniture Chairs Easier On Your Back
by DoItYourself Staff
Patio furniture chairs are all about style and panache, but when it comes to your back, does all that really matter? You may be tempted to pick up the latest style and trend, but then, are you ensuring that these are not going to hurt your back in the long run? You need to consider a couple of things though that will ensure that you are buying good looking furniture which will be a safe investment for your back as well.
Materials
This is the easiest criteria using which you can eliminate poorly designed chairs. A majority of the time teak or other wooden materials are used to design your chairs. Cheap and mass produced furniture chairs are designed using plastics or cheaper metallic materials. Patio furniture chairs designed using aluminum are extremely durable and usually very sturdy for the back. Wood patio furniture chairs made of materials like cedar, redwood, or oak are long lasting and usually have good back and lumbar support. Avoid buying plastic patio furniture chairs as these are generally not designed well and do not last as long.
Type of Furniture
When you start off designing your furniture, you would want to make sure that you are using the right elements, and not adding all sorts of things because you can. Choosing furniture chairs that balances style and function is important because it will ensure that you do not compromise on either. The other thing that you can consider is the variety in your setup. Do not include items that look good but have no worthy function. These kinds are best avoided to the maximum extent.
Ease of Use
Sometimes, patio chairs may look innocuous but when you use them, you realize the problems associated with them. The ingress and egress may be a factor and this could end up hurting your back. Always make it a habit to try out the furniture chair before you buy it. It is only when you actually sit on it that you will know the intricate details which may have passed your eyes when you were shopping for it. Other factors that you may need to consider are if it will be just as easy to use on your patio. Buying the best chair without considering physical dimensions can be problematic and you may end up placing it haphazardly that could negate the benefit of buying it in the first place.
Other Hazards
In addition to the ones listed above, there are other potential hazards associated with the furniture chairs as well. These may include sharp edges or unfamiliar nooks and corners in the design. It is best to ensure that these hazards are as few as possible, if not zero altogether. Most of the well designed furniture chairs do not have any such known hazards and is designed keeping not only the style aspect in mind, but even feature an ergonomic form factor that helps in relaxing your back while sitting down. Although it may seem like it is not of the desired contour, higher end patio furniture chairs are scientifically designed and rigorously tested to give you the most comfort in the long run.
 forum activity
