Making Your Mulch Dog Repellent
what you'll need
- Cayenne pepper
- Vinegar
- Lemons
- Ammonia
- Water
- Cotton Balls
After adding mulch to a garden, the last thing you want to have happen is for a dog to come along and dig it up. If a pooch digs through this mulch or spreads it randomly around your yard, it simply will not be effective any longer. So what can you do to prevent such a yard disaster? Well, the key is in knowing what repels dogs. But as all dogs are different, what’s effective with one canine may not be successful with another. Therefore, let’s take a look at a few methods for keeping dogs out of your garden mulch
Step One – Try cayenne pepper mix
Once you’ve figured out the problem areas -- which are those places where dogs return to again and again - try applying a cayenne pepper mix. Combine cayenne pepper and water in a spray bottle. The ratio for this repellent is one part cayenne pepper to ten parts water. Be careful not to overdo the pepper portion, as this may make it unhealthy for dogs. Once you’ve created your mix, spray it on and around the problem area in a fine mist. Be sure to soak the troublesome spot completely.
Step Two – Try vinegar
If the cayenne pepper and water solution doesn’t do the trick, try a vinegar and water mixture, instead. To do this, mix in one part vinegar to five parts water. As before, spray over the problem region with a misty spray, and completely saturate the mulch.
Step Three – Try citrus
But what if dogs are undeterred by both cayenne pepper and vinegar? Do not give up because there are other methods that may well work! For instance, you might want to go with citrus. Chop up a couple of lemons into wedges, then squeeze the juice over the mulch and let it soak in for a few minutes. Next, spread a few lemon wedges around your garden.
Step Four – Try ammonia
Lastly, you might want to drench cotton balls with ammonia and put them in and around the mulch area. Use ammonia sparingly, however, because it is a toxic chemical, which might injure a dog.
Of course, there are also over-the-counter repellents that can be purchased at drugstores and pet shops, if these aforementioned natural remedies don’t solve the problem. But you should always try these homemade fixes first. Not only are they natural, but they’re also less expensive than having to spend money for something you might already have in your kitchen cabinet or refrigerator at home.
It can sometimes be an uneasy balance, when trying to enjoy a healthy garden and raise a family dog. But if dogs are reeking havoc on your garden’s mulch, you can either get rid of one or the other (a horrible dilemma), or you can find something that separates the dog from the mulch. Chances are good that one of the four above methods will resolve your issue.
