Marble Bathroom Countertops: Pros and Cons
If you are planning to install marble bathroom countertops, it is important that you first know the pros and cons of using this material. Maintenance, price and aesthetics are some of the most important aspects that you have to consider before you decide whether to use marble for your bathroom countertop or not.
The Pros of Using Marble as Countertops
Marble is a natural stone that has incomparable beauty. If you use marble as a countertop for your bathroom, you can expect that this part of your home will look more beautiful and elegant. Another advantage of marble is that it is a fairly strong material, so it will last for a long time.
The Cons of Marble Bathroom Countertops
On the downside, marble countertops are quite pricey. Not only are marble slabs expensive compared to other types of stones and materials for counters, but their installation requires professionals and can be costly as well. Also, if marble countertops are not sealed properly and correctly, they are prone to staining. Moreover, some types of marble are semi-porous, allowing liquids to seep in and cause more stains. Lastly, marble countertops are high maintenance. In order to maintain a beautiful and stain-free marble countertop, you have to reseal it regularly.
