Login Error
Close
Matching Countertop Brackets to Your Countertop
by DoItYourself Staff
Countertop brackets can aid in your quest to achieve a clean, flat surface that you may work on or put your things accordingly such as books, or even your kitchen utensils. A clean and outstanding home décor is definitely very rewarding to anyone who is able to maintain such ambiance in his or her household. In order to achieve this kind of environment within your house, it will be best to have divisions and other partitions of your things to promote a well-organized set-up. There are a wide variety of countertop brackets that you may decide on. It is even better to have it matched on your theme design to make it more appealing in the eye.
Metal and Steel Countertop Brackets
These types of bracket are very ideal in supporting heavy countertop such as stone, marble and granite among others. Metal brackets are very tough at the same time has a lot of unique designs that can match your chosen countertop. There are styles that you can even mount above the shelf, unlike those typical ones that can only be installed below and would require people to bend over before they can see. These are very modern and elegant once already installed and is perfect for mirror countertops and the likes. Other styles are made out of stainless steel with chrome finish to add more beauty in it. There are also clamp-styled countertop brackets that are used primarily in bathroom and kitchen countertops that are not too heavy to support.
Wood Countertop Brackets
Aside from steel and metal brackets, there are also available wood countertop brackets that you may choose from in designing and making your house look very pleasant and organized. These kinds of style not only provide back-end support, but add charming architectural detail as well. With its eccentric designs, you can easily decide what shall best fit your countertop since everything is unique in its own way. What’s nice about wood countertop brackets is that you can have the option to paint it and match with some furniture around it such as cabinets and storage boxes to have a uniform look.
Once you have decided what kind of countertop bracket to have in your kitchen, room or bathroom, the next thing to do is install it perfectly in your preferred location. You have to ensure first that you are qualified or experienced in installing it so as not to wreck or misuse the item you just bought. Installation of these brackets is quite simple. However, it will require a lot of patience and certain amount of expertise to be able to properly align it in the wall. You must have the right tools to get the job done. This includes an electric driller to make the installation way easy than to manually do it.
After getting everything done, you’ll surely be surprised of how these countertop brackets remodeled the simple room before into looking very captivating and extraordinary after.
 forum activity
