Metal vs Wooden Spiral Staircase for Your Home
A wooden spiral staircase can be a welcomed addition to a home. It is one of the oldest types of staircases used in residential buildings. A metal spiral staircase is a good alternative to the wooden type. Many modern homes sport a metal staircase. Spiral staircases easily add style and elegance to indoor settings. They’re particularly beneficial where space is a restriction. They also enable wide architectural expression in the way they capture design elements. One advantage of a staircase is that you can change it according to preference. Perhaps you’re considering which type to install. Below is a comparison of metal and wooden varieties.
Pros of a Metal Spiral Staircase
If durability and long life is a top priority for you, metal staircases rate highly. Iron, steel and bronze staircases last a lifetime and beyond. Should your preference be for a softer metal such as aluminum, durability still holds. Metal staircases aren’t easily dented or damaged. In the event of a fire, the staircase is bound to be one of the few salvageable items. Metal yields a strong, sturdy staircase whose stability you can count on. Iron and steel staircases withstand vibrations extremely well. This makes them ideal in earthquake prone areas. The rigid nature of metal guarantees accuracy and uniformity during staircase construction. Metal is also a highly versatile building material. It can be easily formed or welded into a wide range of designs. Spiral or curved staircase designs are easier to achieve with metal than wood. Wrought iron spiral staircases offer a virtually limitless array of designs for homeowners. They’re a good choice if you’re keen on a more decorated staircase. A wrought iron staircase gives your home a graceful look.
Cons of a Metal Spiral Staircase
Metal spiral staircases generally cost more than the wooden variety. The high resilience of the material and various decorative styles add to the cost. Unfortunately, the fine appearance of a metal staircase may diminish with time, especially if made of cast iron or bronze. Unless given adequate protection, the staircase is likely to change in color. Waxing or coating with patina are necessary to preserve the appearance of the staircase. This adds to home maintenance costs.
Pros of a Wooden Spiral Staircase
Wooden spiral staircases are more affordable than metal. This allows homeowners to achieve whatever design conceived without being restricted by budget. A wooden staircase adds a naturally warm look indoors, which enhances the ambiance. Wood is warm and comfortable to feel. It is more welcoming, compared to metal. Wood also absorbs noise better than metal. Less noise is generated when walking the staircase, regardless of shoes used.
Cons of a Wooden Spiral Staircase
Durability for wooden staircases is lower than metal. Wood is easily damaged by moisture or high humidity. Extreme temperature fluctuations can also stress the material. Wood must be treated to make it pest resistant. Although wooden spiral staircases are cheaper than metal, installation requires more effort and time. This is because the staircase usually comes in separate portions, unlike the metal variety that comes in one piece.
