Methods to Keep Your Drain Pipes Clear
Keeping the drain pipes in your home clear of any clogs is a task that you should keep as part of a yearly maintenance schedule. When clogs form in a drain, they can cause serious damage to your kitchen, laundry, or bathroom areas by water backing up and spilling over onto the floor.
Most of the time drain pipes are clogged over a period of time through different means like build up of water deposits, roots that grow through the pipes, and other things that are forced into the drain such as hair. Keeping them clean will mean that the waste flows better through the drain and out of your home. Keeping them that way requires some work and routine. Here are a few ways to keep your drain pipes free and clear of any clogs.
Mark It on Your Calendar
Keeping the drain pipes in your home clear of any clogs must be a part of your yearly maintenance routine. At least two times a year, in the spring and fall, you should take preventative measures to ensure that your pipes remain free of clogs. These steps are not overly time consuming and will definitely save you a lot of money in repairs later on.
Keep Watch for Roots and Trees
It is highly recommended that you know exactly where the main drain pipe leaves your home and empties into a sewage tank or town waste disposal. By knowing this location you will be able to tell if any trees or roots may be impeding upon the line. When roots grow close to a drain pipe it can do two things. First, they will grow around the pipe, and eventually causing it to crack from the pressure. Second, it can grow right through the piping. Trim back and trees near the drain pipe and stop the growth of any roots that you see headed towards the drain pipe.
Pour Vinegar Down the Drain
In an effort to keep your drains clean in a natural way, you can use vinegar as a cleaner. Simply mix one part of white vinegar with five parts of water and pour it down the drain in the spring and fall. It will travel through the pipes and keep anything growing from going any further.
Have a Water Softener
A water softener is mostly thought of when people want to keep their water supply lines free from clogs. But, you must remember that what comes into the house, must also leave the house. The water softener is a continuous way to keep your drains pipes from clogging, but do require some maintenance. If you have a water softener you will need to add salt to it and keep the filter clean.
Use a Plunger
The only time that a plunger is thought of is when water is running out over the lid of the toilet. However, with a small plunger you can work yourself around the house and keep drain pipes clear. The suction from the plunger will work at the loose deposits, and hair build up, to keep the water flowing. Give each of the drains in your home a simple plunging a few times a year and you should have no problems.
