Login Error
Close
Easy Mildew Stain Remover Solution
by DoItYourself Staff
Mildew stain remover solutions do not have to be difficult to make. You can follow some basic steps to remove the nasty substance from your home. First you should remove any loose mildew from the area by either wiping or scraping it away. You can create a simple mildew stain remover solution:
• 1 Cup Water
• 1 Cup Bleach
Combine the mildew stain remover solution in a spray bottle. Spray the infected are and allow to work about 10 to 20 minutes. Once the mildew stain remover solution has set in, scrub away with a soft bristled scrub brush.
Where To Use The Mildew Stain Remover Solution
Mildew can be found in various places, making it necessary to use the mildew stain remover solution:
• Showers and Tubs
• Sinks and Faucets
• Refrigerators
• Basements
Anywhere that could be damp and not cleaned regularly can be a target for your mildew stain remover solution. You should always clean the surfaces thoroughly, as the mildew can reappear if any spores are left behind. Get your mildew stain remover solution out and begin spraying.
 forum activity
