Login Error
Close
Mobile Home Replacement Windows
by DoItYourself Staff
Mobile home replacement windows are used for the same reasons that homeowners replace the windows in their houses.
If your mobile home windows are drafty, damaged by weather or hard to operate it is time to think about installing mobile home replacement windows.
Many older mobile homes had jalousie windows that opened outward.  Today’s mobile homes are equipped with vertical or horizontal sliders.  Some mobile homes may even have double-hung windows.
Installing mobile home replacement windows
Using a professional to install mobile home replacement windows is great if you can afford it.  However, if cost is an issue you can do the job yourself.
Mobile home replacement windows come in standard sizes.  Measurements must be taken of the window hole.  Ideally, the existing window is taken out and the hole is measured.
Sizing can be accomplished without removing the window by measuring the window only.  Do not include the window trim or the outside window flange when measuring.
 forum activity
