Login Error
Close
Modern Bathroom Tile Options
by DoItYourself Staff
Installing modern bathroom tile is the easiest way to add value to your home. They come in a variety of styles and designs. You can choose the style and design you want, depending on your budget. You can buy them from your local tile supplier or from the local warehouse outlet at a cheaper price.
Tile Size
You can choose any size of tile as you like. Larger modern bathroom tile is the most popular ones, as they make a small bathroom look more spacious.
Color Palettes
The trend in tile color is changes almost daily. The most enduring popular color choice is shades of green. If you have a small bathroom, go for shades of grey in you modern bathroom tile.
Ceramic Tiles
Ceramic tiles are made of clay and are fired in earth kilns at very high temperatures. Modern ceramic bathroom tiles are available in both glazed and matte finishes. They have been the most popular tile material for years, because of its durability and versatility. They are more affordable and are available in any color, size and design. They are easier to install, making it a good choice for do-it-yourselfers. Glazed ceramic tiles are also stain resistant and withstand everyday wear and tear.
Porcelain Tiles
Porcelain tiles are made of porcelain clay and are fired in kilns at higher temperatures. The fact that porcelain tiles are dense and resistant to chipping makes them a popular choice among new homeowners. They are more hard wearing compared to ceramic tiles. These modern bathroom tiles have glazed surface and are resistant to stains. They also have moisture repellent properties. This makes it a good choice for use in bathrooms. However, they are harder to cut, making it impossible to lay yourself.
Mosaic Tiles
Mosaic tiles are also in great demand. They are very small tiles, but are expensive. Mosaic tiles are usually used along with other larger tiles, to accentuate a particular part of the bathroom like the shower wall or the vanity splashback. Mosaic tiles in vibrant, contrasting colors will give your bathroom a designer look.
Terracotta Tiles
Terracotta tiles are also a form of clay tiles, which are usually handmade. This makes them expensive compared to other types of tiles. These tiles are also porous, so they need to be sealed to use in bathrooms. Sealed terracotta tiles can be used in light wet areas of the bathroom. They are also easy to install, as they are can be easily cut using diamond blade tile saws.
Quarry Tiles
In old times, quarry tiles were obtained from quarries. But these days, they are manufactured artificially, which make it as hard as stone. The biggest disadvantage is that these are very porous, so should be used only on light wet areas of the bathroom. However, these tiles have anti slip properties, which make it an ideal choice for modern bathrooms.
Glass Tiles
Glass tiles are the most expensive tile of all. As the name suggests, they are made of glass, so careful handling is a must. As they can break easily, these tiles cannot be used for bathroom floors. But they can be used as wall tiles for a sleek, contemporary look in modern bathrooms.
 forum activity
